Different spark plug in winter?
adriano.ro
My ec 250R 2014 run nice,but I have a lot of spoonge. My set up is p45 main 180 N3CW@3 as1,5 spark plug is BR7ES ,can be this part of unborn fuel?. Start good ,idle very stabile.
Drop your needle one clip. Plug won't make any difference, but it should be a br8. Iridium last the longest for me.
Just so I make sure im understanding your advice you mean raise It one clip so it drops lower? I.e. the higher the clip position the leaner it is?. I have pretty much same jetting as above tiny spooge but fouled a plug last ride. Wondered if im to rich. Gone for the irridium plug this time br8eix i think it was
Make the needle lower, this reduces fuel where you use the throttle most and are likely experiencing problems
thanks was just making sure I understood correct. i.e. I need to move the clip up one notch to drop the needle down. ive got the JD blue needle but might try the N3eg ive also got
