Do KX front plastics fot older gg?
I've been told the rear plastics fit the ec300, will the rad shrouds fit too? Do they need some rogering or are they miles off?
94-98 rear plastics are bolt on. Shrouds are not. You can swap in a KX tank, but tabs are required to be welded to the frame. I did swap an old GG tank into a KX frame, ground the Kawi shroud tabs off the frame and used black Gasser rad shrouds. Sold it to the first guy with 1500 bucks in his pocket. If an oversized tank fits your requirements, the GG frame can be modded to use the Kawasaki tank & shrouds(black of course).
Hi Bowhunter007, I'm going to stick a GG oversize tank in a KX and would love to hear from your experience..
Do both tabs need cutting? As the plastic shrouds look pretty similar. Do you know if any more modern shroud would fit that 07 Clarke tank. 06-08 kxf? 11+ GG.
I will attempt the GG subframe mod on my 97 kx 250 too.
Let me know if I'm being foolish, I'm analyzing before the big order.
Many thanks
2002 KX 250 IMS tank on my 02Ec300 . Not an exact fit but close.
The GG vs KX shrouds are totally different. The shrouds and tank shown in the photos are 02KX250.
Ok so no green shrouds possible for a GG Tank.
I've got a kx with yzf suspensions. Kxf triple. Gg tank and Husqvarna footpegs.
I had to trim 25mm off the front of the seat and the kx tank pushes the seat up a bit so it is less flat.
