skid jackson
getting ready to do this for the first time.
When you pull the jug do you have to pull out all the power valve stuff first, or can you pull the jug with that stuff in place and remove it when you've got the jug on the bench??
Also the the nut that is on the head that sits to the right of the front engine clamp does not have enough room to fit a socket in there. the mold for the cooling hose fitting gets in the way. I ground down a twelve mm box wrench to get it out but that won't really work with torque wrench, .... guess I could get a socket welded to the wrench. Can you grind a socket down some and also grind a bit off the head. or does taking adremel to that section of hte head sound risky
