EC 125 Supermoto conversion
Noobi06
Hi, Ive got an EC 125 2005. The axle sizes are 25mm front and 20mm rear.
Im converting it to supermoto and I need to get my hands on wheels. I can not find any 25mm and 20mm wheels. However KTM EXC use 26mm and 20mm. In that case I would need to get new bearings at the front to fit a 25mm axle right? And the spacer I would just use my old one.
HOWEVER
The rear wheel, there is both the break disc and the sprocket. Both of them needs to fit. Please help
I rely on you Anders :)):cool:
Ok, here I am
You are right, the rear wheel can be tricky. Not that the sprocket and disc must line up, but you should preferably end up with the wheel on the bike's centerline as well
I have seen pictures of gg bikes with cast wheels, perhaps from a Mito or RS125 (road bike) if I remember correctky. I also semm to remember someone using a Suzuki rear wheel, possibly from a 500 fourstroke twin?
If you search the forum, some images may appear.
You have several ways forward;
-Try to find / buy gg hubs and lace them up.
-Or you could lace 17" rims to the hubs you have.
-Try to find gg 17" wheels (there are some pair out there).
-Bring out your calipers and other measuring gear and find a rear wheel close to what you need, then go on modifying.
I haven't done this on a gg, but I have made a pair of PVM magnesium rims fit my supermono. That sure was some hours in the lathe and mill, but the result was worth the effort.
My son built a EC300 SM bike, he was lucky to find oem gg wheels locally. Added some isr brakes and got a nice am bike.
Ok, here I am
http://www.gasgasrider.org/forum/showthread.php?t=21489
Thanks a lot Anders! I will make sure to post the final results when those are ready. Weeks or months, well see. I started out here as a beginner and now my engine is done :) Somehow managed to learn it from youtube
I was thinking of lacing rims to my hubs I have now, but I have heard gasgas has like vice-versa lacing so that wouldnt work?
It would work, but you will have to use rims drilled the correct way.
Did you study the forum thread I linked to? Where it said that the Italian Husqvarnas have similar hubs / wheels? I cannot confirm that, but getting hold of a set of Husky SM wheels should not be that difficult in Sweden, I presume?
Yes I did. The wheels linked have axle size 30mm front and 25mm rear. Im gonna ask if the width of the hub and see if its the same. If it is, and I get new wheel bearings so my axles fit, do you think they will work? Sprocket isnt a big deal, since I can buy the sprocket for the bike the wheel is made for. I dont think brake disc is either, since I can make own holes in the disc.
https://www.facebook.com/marketplac...wse_serp:9204db37-d050-4f59-b4e1-e77a6b19f97d
I think 5" is too wide for the rear. With a 5" rim you must have at least 160 width tire (on my Supermono I have just that, BT090 160/60 on a 5" rim) and that will not fin in my GG swingarm. The tyre will hit the swingarm, and the chain will hit the tire.
The OEM wheel kit has a 4.25 rear rim. Perhaps that could tell us something :D
OTOH, the rim is quite affordable. If you buy this one and lace up on an original gg hub, you are done. They also have spokes. As we have discussed, the front is easier, there you could fit almost anything (within reason).
There is also an undrilled front rim. Then, you could drill it to the gg lacing pattern. But you'd have to be sure that it is undrilled, and that you know how to drill it ;)
With the 125 engine you dont want to go too large with the wheels and tires. While it may look cool, they will eat your limited power and add weight.
The OTOH rim was very nice Anders. Can you find a front rim aswell?
I was thinking of buying the rear one you linked, and a front one if you find one.
These spokes for the front and I dont find spokes for the rear.
I linked to an undrillled front rim.
But as I said, you have to make sure that it isn't drilled. You can drill it with the gg pattern, but I cannot tell you how to do that. You'd better seek some help at a local wheelbuilder if you can find one.
