strokeofgenius
My bike spewed white crap all over me and bike last night,it was a mixture of oil and coolant.both oil and coolant levels were very low so I suspected water pump seal.when I removed pump cover it seems there is no seal between engine cover and pump assembly just metal to metal.Is this right or should there be a seal.Also it seems that the impellor is damaged as I can turn it around without any resistance, ie not being turned by clutch.All the white gunge was coming out the power valve vent so can only assume it overheated and that was the quickest way out.Any ideas folks.Thanks Gene.
