EC 300 2012 Rear Wheel Spacers
exman
I'm in desperate need to renew bearing and seals on the rear wheel and replace badly worn spacers, but all I can find on Ebay are for 2018-2019. Does anybody know if they suits 2012 model?
So after last set were out I got some stainless sleeves turned up and pressed on the old turned down spacers
2012 rear spacers
I have two rear spacers(alumn) . New take offs. I decided to go with steel instead . They share the same part # so be careful and ask if ordering.
Get the spacer, bearing, and seal kits from SKF.
http://www.innteck-usa.com/products/wheel_seal_bearing_kits/?ProductID=436
Thumbnail.aspx
Nice find Gerard!!! Please forgive me i thought the original poster was referring to the spacer between the bearings
The SKF kits are outstanding. The seals have a rotating section that sits against the spacer so you don't get friction and wear of both parts. You can notice the friction reduction if you just push the bike along by hand.
