Gasgasogeros
hi on my gasgas ec300 the piston its not openull the sub ports by 4 mm with cylinder gasket 0,15 is normal this, or its must make a gasket 4 mm to open the subs ports?
f
[/IMG]
f
My question is this its comon on gasgas or something mistake on my bike ? because the piston is not oem but a vertex i know the heed must cutting on laxte the same as the gasket on base of cylinder
On my 03 mc250 I expermented wirh raising the cylinder to ensure the exhaust port being fully open at bdc and then cutting the squish to make up for the lost compression, it ran like a turd with a much narrower power band. I finally removed one of the base gaskets to where the comp was 200 psi and it ran much better.On my next 250 ec I just went to the thinnest base gasket and left the head alone, the compression again 200 psi. The result being a sweet torquey, flexable wood engine that stokes everyone who rides it, who'd a thought.
