EC/ EC-FSR frame
Hmm.. Seems like nobody knows what frame is on a four stroke gasgas?
If you own a 400-450 gasgas could you please post here, or send me some pictures of the "bottom" of the frame, with or without skidplate..
Thanks in advance.
On the 450 the skid plate is fastened with three bolts onto threaded clips that are placed on welded mounts on the inside of frame tubes. Does the 250 have these mount points?
I doubt there is a chance of direct fit, however a bit of machinig and fabrication of your own mounts would likely make it fit.
on page 68 is included the factory sump protector, there you can get an idea of placement of bolts. http://www.gasgasmotos.es/en/manuals/download-2006_fse_450_4t_partlist1.pdf.html
