Ok we'll start again.
So you geared it, I'm going to guess Up rather than down so it could achieve a higher speed before hitting top revs in 6th?
The gearing won't affect the engine. The air mixture or fuel type vs ignition timing (usually fixed) could cause detonation that rapidly destroy pistons.
But tell us about the usage. Were you screaming its guts out full throttle, or had you just closed throttle?
