Hi, Ive got a Gasgas ec 125 2005. Is the gas tank tube important?
Also the carther breath tube for the engine, one end connects to the engine, where does the other end go?
Also, i only got 1 radiator cover, or is that normal for the ec125?
1) Yes. Allows the fuel tank to breathe and not let fuel splash back on you.
2) Just run it up alongside the right radiator, or under the tank. Doesn't connect to anything.
3) Should have 1 on each side.
The tube coming off the fuel cap is stuck into the the triple clamp steering stem nut.
Radiator cover helps with cooling and some protection from trail debris.
