Bearman
G'day,
I just did the top end on my bike. The bore was fine, and the piston was good, so I just put new rings, gaskets and o-rings in it. The compression was down to about 90-100 PSI. Now that I've re-done it, its only up to 150 PSI cold. I remember someone talking about a 250 or 300 and were quoting 175 or 180 PSI. Is this right for a 200? It had two green gaskets when I pulled it apart, so thats what I ordered. If my reading is low, would removing one of these fix up the problem if I had enough head clearance? Everything was put back together correctly. we've checked that. Dad's a full on mechanic, and he's pretty good at it too.
Any thoughts on what the compression should be for a 200? I checked all the manuals I've downloaded form the GasGas site, but havent found anything
Thanks guys
Thanks guys
