Leon_gasgas
Hi all!
After checking for damages in the gearbox of my bike ('98 year model) I would like to ensure that I put back in the correct order all the parts. The manual is clear enough for the order of the sprockets and the shift forks but not so clear for the mechanism which shifts the forks. Can somebody instruct me for its correct position in relevance with the forks?
Now I have put it in (I haven't assembled the cases yet) with the 2 left forks placed in the "lowest" (deeper?) "path" and in the "highest" path respectively on this mechanism. The one right fork is placed naturally in the middle path of this mechanism. Is this the correct order? By hand it shifts the gearbox into two obvious positions. The one in which everything turns around and the one in which (as I remember) 1 or 2 sprockets don't turn around. Into how many positions the gearbox should be shifted by turning the drum by hand?
Here is a picture of the forks in relevance to the primary axis and the drum. It is natural to me that it should be like that because the primary axis can receive one fork only. Can somebody verify?
http://img142.imagevenue.com/img.php?image=86949_GG_gearbox_split1_448lo.JPG
I hope my description is clear enough for you to understand! Waiting for your replies!
Thank you!
Leon
Thank you!
Leon
