roverhybrids
Anyone have thoughts on building an ec300 as a dualsport? This would need to be comparable to the newer ktm/hisky/gasgas 500 4-strokes I have a 2001 ec300 engine as well as a counter balanced engine
I would never do that with either of my 300s. I had to ride my 2014 EC300 for 15 miles of 60 mph highway with a group of others and we kept it at 55-ish and the 2014 had the stock choke lever on the handlebars. I tapped that lever every 5-10 seconds to keep it from seizing. I don't want to have to do that again! Stick with the big KTM 4t.Ideally:
Maintain speed of 50-60mph
Handle 1 hour* of continuous pavement
Not blow up!
Pavement will be avoided as much as possible. No interstate. 1 hour is hopefully worst case and not the norm
Is that really necessary? How do 2-stroke scooters and street bikes survive?I would never do that with either of my 300s. I had to ride my 2014 EC300 for 15 miles of 60 mph highway with a group of others and we kept it at 55-ish and the 2014 had the stock choke lever on the handlebars. I tapped that lever every 5-10 seconds to keep it from seizing. I don't want to have to do that again! Stick with the big KTM 4t.
You need another atk 605 ? U had one years ago and sold to friend . He told me recently the e start stopped workingI use my plated 2018 300 (stock gearing) for dual here in Colorado and it works well as long as you keep speeds below 50 mph for any sustained riding (I periodically press kill switch to give it some "richness") and distance of less that 10 miles on pavement. Those are the upper limits in my opinion. I've gone faster and longer but I generally stay below 40 mph on my forest road/trail rides and I can ride a hundred miles a day like that. One thing to remember with a 2 stroke with riding faster and longer is that the exhaust has little droplets of oil in it that will stain whatever you are wearing at higher speeds as it seems the aerodynamics makes the exhaust "curl back" into your body.
In sum, if you are serious about dual sporting with significant miles on pavement, you need a 4 stroke. I always truck/trailer my EC300 and only use pavement as a last resort for connections. My solution is to have both as I have an ATK 605 that rarely gets used as I don't like street riding. Good luck with your decision!
