EC300 exhaust
Brekizer
Goodday!
The exhaust of my '02 Gasser EC300 is not in the best shape anymore,
Do exhausts of newer EC300 fit? On pics they basically look quite alike/the same.
I put two different 2007 pipes on a 2003 GG300 and 2004 GG300. As I recall I needed to shorten the pipe slightly so the muffler would go on all the way and I think I needed to either slightly bend the pipe mounts and or drill a new hole to align with the lower rubber mount. I think one may have also needed a minor dent to provide clearance for the radiator bottom tank. It was relatively easy and I would not hesitate to do it again.
If that's all then I don't think I'm gonna have a hard time finding a new pipe :)
Thanks.
Edit : What pipe is recommended for a bit more bottom end grunt?
Excellent news! Could you have drilled a hole in the lower pipe bracket to align with the original mount?
Smells like too much of a bodge to me ;)
Especially considering the cost of mounts...
Those mounts look very similar to the original. Was the new one longer or was it offset between the input and output mount locations?
I believe it's pre 07 has straight mount as above. And post 07 has offset mount like such.
