Can anyone help, have a 1999 ec250. I am looking for a wiring diagram, the wee beast lighting is up to 18V so as long as it does not pull away the bulbs stay intact.
Sounds like your voltage regulator is failing. It's usually a small square black device with one wire connected, often mounted near the coil. The first step is to check the connections. Most important is that it has a solid ground point.
