Final drive seal?
Clean area. Remove sleeve (can be stuck to countershaft if not greased). Hook out old seal with seal tool or offset screwdriver (careful not to scratch surface in cases. Remove o-ring. Drive in new seal flush and square. Replace o-ring (new). Replace sleeve if grooved. Shim countershaft sprocket to fit snug with circlip in place (to minimize movement and compress o-ring).
