Fitting map switch to 200?
blanc
Hi all, My cdi is in my airbox it has a black and an orange wire that are unplugged. How do people fit a switch to change maps? Also what map is it running with wires out? Steve
Unplugged is the soft map, if your able to solder wires together you can buy a switch and wire it up.
Otherwise I think you can buy a switch from GG which will plug in and work that way.
Plug them together and try it before you wire a switch, the difference may not even be noticable on the 200 depending on the jetting and how you ride it. Even on the 250 its hard to tell.
do the black and orange wire allso apply to the ('00) EC300 CDI?
i would like it a litlle more smooth.
i allready have the FWW.
thanks guys, hannes.
I believe the dual map cdi was only introduced in 2005/2006
So no, unless you have a newer cdi you will not have a dual map.
Sorry
Correct, only some '05 and later bikes. What you can do is jet it a little different, and retard your static timing a bit.
