Float valve.
masterbill
Hello,
Two bikes 2006 EC 300 and 2014 EC 250.
Does anyone know if the float valves are the same in the round top carb and the AS2 ?
Cheers Bill
Hello,
Cheers Bill
Nope, screwtop has deeper float bowl. Height should be 16 mm, I believe, or seam parallel with bottom of carb body. Short body carb height is approximately 6mm, most run a tad lower, I run mine at 7.5mm.
