fly wheel play?
jgasser
hi all im looking for some help ,ive took of the flywheel cover and I can not feel any play in the crank by rockin the flywheel put if I push it in towards the other side of bike there is some movement is this normal or could this be some think loose or not seated correct ? starts 1st kick and seems to run fine any ideas would be great. thanks
A little axial movement is pretty common but you should not have radial movement.
