You can Put a carbon fiber pipe guard and rubber under coat your skid plate also if you want to drop some sound. cause from what I've witnessed at NMA sanctioned event sound tests, there isn't a whole lot of difference between a Q's sound output and the turbine core 2's. Much of what noise is picked up on a sound meter is not from the muffler but the motor. Its amazing how much noise is generated from the engine area and expansion chamber. It is very easy to tell how much sound is coming from the engine area when you do put on a super quiet muffler or add on like the db snorkel like jeffd mentioned.
