I have access to liquid nitrogen (LN2), you should see how good that works! Both LN2 and dry ice will freeze moisture from the air into the bearing, so its important to rewarm the finnished case assembly to drive it off, and lube when cooled. Use heat,cold, and finese rather than force and you will be in good shape.
