I run mine at 105mm, spring out. This equates to 540ml in each leg. If you do a search you should be able to find quite a few posts on this. From memory, my level is a little higher than most. It works fine for me - I am 75kg, stock springs. The oil height affects "bottoming out" characteristics.
