The Sachs and Marz fork are almost identical inside and out, except for the cart piston stopper and valving.
If you don't like the Sachs you won't like the Marz...at least not in stock configuration.
Your wasting your time and money swapping forks.
I hated my stock suspension, I couldn't keep the bike on the trail but our trails are all roots...wet slimy roots...so slippery it's named Hawaiian ice!
I revalved my forks and after multiple tries I finally got them working great, so they can be made to work right.
My best advice to you is to get them revalved and set up right for your weight, skill level and type of riding you do.
I ride with a guy that had his suspension (09 EC 300) re-worked by Les from LT racing.
I road his bike because I wanted to compare his bike to mine and Les did a good job.
The suspension was plush over the roots, rocks and other trail trash with little or no deflecting...yet it was compliant and bottom resistant on G-outs and other higher speed hits.
