skid jackson
how much freeplay if any should there be between the inner fork tube and out tube?? When rolling the bike on the drive way when i hit the front brake I got a "shimmy" effect I thought maybe the steering stem bearings needed attention. It turns out that if you grab the bottom fork tubes down where the axle is and hold it just right you can shake the inner fork tube inside the outer fork tube. There is/was enough freeplay to make me thing my bearings needed attention. To local gas gas racers said it was a normal upside down fork thing.
