Frame gaurds
Dualscotty
Hey guys. I am in need of frame gaurds for my 04 ex 300.what other newer years model frame gaurds will fit. Thanks. Scott
Thanks. I see you are running the lectron carburetor. I have been considering one for the simple reason of never fooling with jets again. Thoughts? Thanks. Scott.
The Lectron works very well in my bikes. It worked so well that I moved it from my old 06 model to the 2015 when I bought that one.
I purchased it directly from the factory in the US. Just told them what bike I had and received a carb that was plug and play.
I'm very happy with it, have used it for at least 350 hours riding over the last 6-7 years.
As long as everything else on your bike is good they are great. With a jet carb you have a lot more adjustment to jet around issues you may not even know you have but not so much with the Lectron. I just experienced this with my 18, I could get the Keihin pretty good but not the Lectron due to the gigantic squish of the stock head. I corrected my squish and now the Lectron works great.
In my '15 200 the Lectron worked ok even with oem squish, but after I turned down the head, everything, including carburation, of course worked better.
