J Jacob 'Berg Member Feb 16, 2015 #1 The clutch is slipping at high rpm in taller gears. Will any of the aftermarket friction plates suffice, or should I buy OEM? Are the drive plates in the gassers aluminum? If so, should I replace with steel drive plates?
