motopsycho87
Has anyone else experienced brake drag on an ec? I've rebuilt my caliper, master cylinder and changed the hose but I still only get about 3 turns on a good spin on the front wheel?
Everything is moving smoothly, pisonts etc, pins are clean and greased, disc is true to 0.2mm, but the wheel doesn't turn under the weight of a padlock on the disc!
I've completely run out of ideas! Bracket appears to be true also. And there is free play in lever.
