I've found that it's real easy to fit most made for Yamaha YZ Disc Covers (I use a Cycra YZ cover) on the late model GG's by relacing the OEM front axle bolt with a solid steel one.
The bolt that I use can be found at any hydraulics parts supply store. All that is necessary is to drill through it and tap for the 10 mm bolth that holds the cover. It's a 5 minute job and it works great (see the attached pictures).
Kent
Kent
