Hi guys got a gas gas ec250 off 1998 but i got the stock suspension on it. It's not an USD but a standard fork. Now my question is does anybody nog witch suspension oil it need en how much?
Thanks redlug!
I sent Jeff , the webmaster, a .pdf file copy of the Marzocchi 45 and 50
Magnum service manual to place in the files section. So far I do not see it
there.
Here is a snippet from the file, I hope this helps.
If you would like a copy of the .pdf file send me a PM with your e-mail address.
The file is a little over 2MB.
Pour ?MARZOCCHI SAE 7.5? oil (Ref. 550013) into the stanchion
tube and into the inner rod, making sure that also ducts inside the
damper are full. More over you have to pump on the shock absorber
rod-keeping the rod hole closed to be sure that the cartridge is
completely full. Fit the inner rod (1).
Check that an air volume of 140 mm is left between the top of the
stanchion tube and the oil level, with the stanchion tube at its end of
stroke.
Cheers, JJ
