FSR 450 info
Suspension setup would be the first step for MX IMHO. Hopefully the gurus will chime in shortly :)
Edit: My suspension is standard and a bit soft (rear) jumping at 86kg
How light can you make it?
Anyone tried motocross with one?
YES I HAVE!! I USED THE MC FRONT FORKS AND TOOK OFF HEADLIGHT,TAIL SECTION AND THAT WAS ABOUT IT. YOU MAY HAVE TO FART WITH THE GEARING BECAUSE THERE IS NO WAY YOU NEED TO GO 90 MPH. LOVED IT, HAD NO PROBLEM PULLING HOLE SHOTS AND WINNING ON IT. WHEN IT DOUBT TWIST AND SHOUT!!
