Gas gas ec 300 crank shaft nut
palec456321
Hi i need help.
I did a general overhaul. I replaced the crankshaft seals. and when I tighten the nut (crank shaft pinion lock nut).there is the opposite thread. I found on the Internet that he needs to be tightened on 98NM. but when I tighten it to approximately 70NM .the crankshaft is very difficult to turn. should it be? can new seals do it?
Thanks for help. And sorry f?r my Bad english.
Hi i need help.
Did you split the cases? If so, I would check to make sure that the crank is centered between the cases. If not, you may need to hit the crank shaft with a mallet or brass hammer to get the crank centered in the cases.
You should not need much force with the hit.
Agreed, if a light tap does not do it, I would try and use another method, such as a crank installer tool to assist with the light hammer tapping.
If you hit it too hard you could force the crank out of true.
