GAS GAS Trailtech Vapor Speedometer sensors
dimtsam
Hello everyone
I got a GG EC 250 2011 and there ' s a Trailtech Vapor on it. But the cables are cut off. And there are no sensors...I need help to identify the cables coming out of speedo. I know which pair is the Power.
The engines temperature sensor has 4 wires? Can I replace this sensor with an other except Trailtech's because I think is too expensive?
Is there a cable that goes to spark plug?
I need any info that you can give.
Thanks a lot
After contact with TrailTech I finally found out the answer. So I'll try to put some infos here in case someone else need this.
The speedometer
The first cable from the left with the connector is connected to Power 12v. The second is for tachometer sensor. The third, which is red marked, is a 4 wire cable that is connected to remote switch (which is no longer available). The last cable is for engine temp sensor.
