skid jackson
CHECK THOSE EXHAUST MOUNTS!!!
while doing an end of the year tear down, I noticed my hyde combo skid plate had been wearing against the water pump cover. When I pulled the gas tank out I noticed something had been wearing against the tank. Further investigation revealed that my upper exhuast pipe mount had broken its weld in the frame and was basically free floating. This allowed the pipe mount bolt to rub against the gas tank. the wear wasn't bad but .. if left unchecked .. I gotta wonder how long it would take to wear a hole in the tank!! glad I found it. I decided to check the lower mount and found that it is also free floating, but appears to be designed that way. although it was cruddy enough that maybe it too broke. Anyone know if the bottom mount is suppose to be free floating. the parts fiche would have it appear that it is not. however my parts don't look exactly like whats on the parts fiche. 06 300 btw
