GasGas Front Axle Grab
Berkyboy
We've had great feedback on this Front Axle Grab, retail 24.95.
It fits most 2004 and newer front axles with hexagon (six sided tooling inside the axle) without any modification. I say most because GasGas machine tooling has a lot to be desired sometimes. Some of the OEM GasGas axles need a little filing to remove a burr that forms when the axle is made. If you have one of these I'm told it takes 2 or 3 minutes tops to remove the burr.
Also make sure you check that you have the six sided inner axle reciever. Some of the axles used by GasGas (most likely from a different supplier) have a smooth cylinder bore instead of the hexagon shape. We've already got that one in production so if you need one of those call.
Photo here: http://berkyboy.smugmug.com/gallery/2240399/1/116843897/Original
More info here: http://www.gofasters.com/index.php?main_page=product_info&cPath=89_94&products_id=2221
Yep' got mine from you guys a few weeks ago.Haven't installed it yet cause Les has my bike. It's gonna be so nice to be able to remove the axle easily now. Well worth the loot in my book.
Later, Roscoe
