VintagePhill
Hi Guys!
I am having a bit of trouble with my KYB Forks on my GP Edition.
My Dad recently got a 390 Beta 2022, which also uses the Kayaba 48mm Suspension. While testing his new Bike I noticed that his Forks had absolutely no stiction while riding.
The slightest compression while sitting on the Beta compresses the forks extremely smooth. Sadly thats not the Case for the GasGas Forks. The Stiction under load (while sitting on the Bike) is quite high. You need to really try to compress the forks to get them to move.
I tested this further by removing the forks of both bikes.
Using my own bodyweight to compress the forks I feel no difference in terms of stiction between the different forks.
But if i apply a Sideload (not only pushing vertically, but trying to "bend" the Fork while compression) my Forks start to stick like crazy...
Things I have already done:
Because the Bike is the GP-Edition I have the DLC Coating on my Kayaba, which the Beta doesn't have. The coating looks good and should counter the mentioned stiction as far as i know?
Do you Guys have any additional Ideas that I could try?
- Changed Seals and Bushings (OEM Kayaba)
- Used new Oil (300ccm 2.5W)
- Bled the inner cartridge( with new oil)
- aligned the forks while tightening the Axle (I even tested without tightening the Axle and retaining bolts - no improvement)
- used lower than specified Torque for the Triple Clamp (10Nm instead of 13Nm and 17Nm)
- Used silicone oil and Spray to treat the Seals (very slight improvement for 1 Ride)
