Looking to see if we can find a rear and front hub similar to gasgas.
The most important factor is the distance from outer sprocket to outer rotor. I can figure out the spacer/collar/bearing arrangement later.
Rear hub on the GasGas outer sprocket to outer rotor is:
6 3/8
Front hub measure from outer of rotor to outer hub flange:
4 5/8
The rear of a 99-18 YZ/YZF comes in at
6 3/8
Front
4 3/8
It looks like a rear wheel of a Yamaha can fit with the a different configuration of custom collars.
Has any tried? If we can find a front hub that matches 4 5/8, that will give many options.
6 3/8
4 5/8
6 3/8
Front
4 3/8
