Can anybody suggest a solution to my '06 GG 280TXT Pro shifting problems? I have trouble selecting 4th gear. The trans makes a grinding clunk sound and goes straight into 5th from 3rd. I can select 4th when I ride very slowly and before the engine warms up much. Also, downshifting is very "vague" and not very positive.
I've checked the eccentric adjuster as per the Video on Gasgas USA's website, and it "clicks" going into 1st and 2nd as the video says it should. My question is, does anybody know which direction I should turn the eccentric adjuster to try to "reset" the shift drum? I want to try that before I go changing out shift forks, gears etc.
I know that 4th gear is the most "complex" gear to select in the trans, but it should shift into gear with no problems. Any suggestions would be appreciated!
Thanks!
Thanks!
