Gnarly Pipe
E-TECH
FMF Gnarly Pipe for all 250/300 from 07 to 11 Part # 117-025095.
Has not been mounted since its return from pipe repair shop.
The finish is dull and there is slight surface rust but it is straight and mounts good. Asking $125 and 10 to ship
Would this fit a 2002 300?
In '03, the motor was rotated down around the swing arm pivot 8mm, and the pipe bend changed slightly in the stinger area, but not much and guys have fitted newer pipes. I have a spare GG OEM pipe from an '05 250 and its the same as my '07 pipe, GG part#s and all. The difference in the '07 fitment is the silencer bend, not the pipe, so it should fit, with some minor tweaking. The older FMFs fit so poor anything is an improvement.
