Good GG engine mechanic
GasGas Mechanic
Doesn't really matter where the mechanic is as long they've got a shipping address. Quality is more important to me than proximity.
Les Tinius at LT-Racing is the best qualified (and simply the best) motorcycle wrench around (and nicest one too). Honda factory trained "master tech" and also ASE master tech. He has done quite a few gasagas motors... www.lt-racing.com
I'm sure Les will be able to fix you up. However, splitting the cases and working on the transmission is pretty easy. I rate it about the same level of difficulty replacing the top end, but it takes longer.
