Grounding the CDI
pscook
I am assembling my XC300 and have a quick question with the harness. I am using this diagram, and don't remember and can't find the chassis wire that connect to the black/white wire from the CDI. The diagram says it goes to earth and continues to the lighting circuit. As I can't find anything in the chassis harness, I am simply putting the black/white wire to a solid earth connection. My loom is very simple (as am I, apparently), but there is nothing that I remember that connected to this one single wire. Am I safe going directly to chassis ground, or is there something I need to know before I fire it off tomorrow?
It's a 2002, and the connection off the CDI is a spade (male). Nothing on the harness that I remember or can find now that it connects with. I'm pretty good with keeping stuff organized, but I just can't remember where this connection went. The diagram shows a frame earth ground, so that's what I am going with unless someone can show the proper method. I'll poke around the bike when I get home tonight and see if anything else jumps out.
could it be the wire that connects to the voltage regulator up in the neck of the frame where it bolts to the ground?
The legend is correct in stating that is a B/W wire with a .250" spade terminal. It should connect to ground at the coil somewhere, along with the common for the coil and regulator. If I remember it may be a short female pigtail off the coil, then everything is pinched under the coil mount. Clean and dielectric grease this. Its definitely a ground so no harm in making a different physical connection.
I'll look again for a spare ground from the coil, sounds familiar. I created a unique and discrete ground for the coil that is independent of the loom, maybe I should rethink that. Thanks for the help.
Found it! Yellow with green trace was in the loom and grounded to the coil. Why didn't I recognize that the Y/G was attached to the B/W? Silly me. But now looking at the diagram I linked to, the Y/G is the ground for the tail lights. Methinks there be some shenanigans afoot.
Thanks for the help everyone. I'll fire it off tomorrow as I have to take the little one to her dentist appointment this afternoon.
