C Cisco New member Mar 18, 2016 #1 I'm changing the oil in my 327 gasgas , which oil is recommended ? It's a 1992 gr32 . The clutch is pretty sticky so I'm going to swap out the oil to see if that helps
VxZeroKnots Gold Level Site Supporter Mar 18, 2016 #2 Try ATF, that is what what recommended to me for my 280txt
cbutler Member Mar 18, 2016 #4 If it has the "edition" motor use 10w 30 motor oil Castro, Pennzoil, Quaker State......... The "pro" motor use ATF
C Cisco New member Mar 18, 2016 #5 I'd imagine it's the edition motor since it's a 1992 , so just regular motor oil .... Prob not synthetic
cbutler Member Mar 18, 2016 #6 Yes I dont recall the volume off hand but have it at the house if you need it.
