my headlight has quit working on my 2004 mc250 following a crash. I get no power with my test light at the headlight terminal, "violet" i have checked the ground at the headlight and it is good. I also get no power at the yellow wire coming from the stator, i do get power from the white wire coming from the stator. If i disconnect the wires from the headlight i then get no power from the white wire off the stator. if i disconect the yellow wire from the stator i also get no power from the white off the stator all connections seem to be fine and the bike runs great. the bulb is good, please help!, thanks all.
