Help Identifying Forks
risk74
2004 EC 300. Forks are gold in color. Sliders are 48mm. Five small grooves around top of fork. Need to find seals/wipers, but not even sure of the make. Assuming Marzocchis? Did they come stock on 04s or have these been swapped? Thanks.
Starting to think Ohlins. Rear shock is Ohlins. Seal dimensions match Ohlins specs. Need to know oil capacity as well. Thanks.
Confirmed, they are Ohlins. Can anyone suggest a place to get seals/wipers and bushings from? I've searched and can find the seals, but no luck with bushings.
Possibly KYB stuff crosses over?
Les at LTR uses KYB fork seals in the Ohlins. Are they 46mm or 48mm?
They are 48mm. Found seals and bushings for them. Now if only I could find the protectors that go on the outside of the fork leg to protect it from the fork guards.
