dANbOT
2014 xc300 re
Has some strange problems the other day and in the end, got stranded.
First, I tried to start my bike after a break and had no ignition / headlight power and wouldn't start. I went through all the stuff I could check in the bush... grounds, fuse, ignition switch etc.
After an hour of fiddling with it, suddenly I had power and it started. I made it most of the way back to the trucks before it died, this time I had ignition power and headlights but no start. As I was being towed back from there, I tried starting it a few times.... it would fire momentarily for a second and immediately die.
So I need to test and find the problem before I can ever trust my baby again.
Does anyone have some testing specs / diagrams for the coil, stator, VR, ECU?
I'd would greatly appreciate some guidance on this one!
Dan
Dan
