nwcycle New member Apr 14, 2010 #1 Hello, looking for info finding a rear Master rebuild kit, Was wondering if any cross Kaw,Suz, ???? Will fit Thanks!!!!
gasgasman Super Moderator Staff member Apr 14, 2010 #2 Yes, they will work. You will need to know the piston size. There's number on the master cylinder body,eg: "3/8".
nwcycle New member Apr 15, 2010 #3 Thanks Once I find it, is there a aftermarket unit, or do I need OEM ?? Thanks
noobi New member Apr 15, 2010 #4 I think you can just use a rebuild kit for a honda CR, as long as the piston size is the same as the kit is spec'd for.
jefgil123 Silver Level Site Supporter Apr 15, 2010 #5 Yes, I just used one from a YZ250 and it worked out. (Don't remember what year)
