spooly New member Oct 1, 2015 #1 im replacing the main barings on my 07 300.. I found the baring size but can find the size of the seals.. can anyone tell me what seals to order? And are both barings left and right the same? (NJ206ETC3) Sent from my GT-I9300 using Tapatalk
Zman Platinum Level Site Supporter Oct 1, 2015 #2 All Balls Racing has them. http://www.allballsracing.com/24-2006.html
M motopsycho87 New member Oct 1, 2015 #3 Check my engine rebuild thread, I listed everything. Also check the parts list, gives generic part numbers
spooly New member Oct 1, 2015 #4 The parts list doesn't give u seal numbers. . Sent from my GT-I9300 using Tapatalk
spooly New member Oct 1, 2015 #5 Zman im not looking to buy.. ill buy my seals and barings locally.. Sent from my GT-I9300 using Tapatalk
spooly New member Oct 1, 2015 #6 Phycho will u link me the thread? Sent from my GT-I9300 using Tapatalk
M motopsycho87 New member Oct 1, 2015 #7 http://www.gasgasrider.org/forum/showthread.php?t=18431 ITEM BRAND PART No 1 x SMALL END BEARING INA KBK 18x22x22 1 x LHS CRANK BEARING SKF NJ206ECP - C3 62x30x16 http://simplybearings.co.uk/shop/p1...l+Roller+Bearing+30x62x16mm/product_info.html 33.76+ 1 x RHS CRANK BEARING SKF 63/28 - C3 28X68X18 http://simplybearings.co.uk/shop/p1...ove+Ball+Bearing+28x68x18mm/product_info.html 1 x LHS CRANK SEAL KOK 20x35x6 - VITON 1 x RHS CRANK SEAL KOK 38x52x7 - VITON 1 x COUNTERSHAFT BEARING SKF 6305 - C3 1 x COUNTERSHAFT SEAL GENERIC 30x40x7 collar 58HRC - 25x38x17
spooly New member Oct 1, 2015 #9 Iv actually ordered the wrong barings by the look of it..but I got one baring size off the parts list??? Sent from my GT-I9300 using Tapatalk
spooly New member Oct 1, 2015 #11 motopsycho87 said: What did you order? Click to expand... (NJ206ETC3) ×2 Sent from my GT-I9300 using Tapatalk
M motopsycho87 New member Oct 1, 2015 #12 spooly said: (NJ206ETC3) ×2 Sent from my GT-I9300 using Tapatalk Click to expand... Nj206 and c3 is what matters. ET and ECP are just codes for the cage type, but as a needle roller bearing that matters even less
spooly New member Oct 1, 2015 #13 motopsycho87 said: Nj206 and c3 is what matters. ET and ECP are just codes for the cage type, but as a needle roller bearing that matters even less Click to expand... Are both sides the same then? Sent from my GT-I9300 using Tapatalk
