M Marc02ec250 New member Mar 20, 2018 #1 Can someone please tell me if the 17mm is high speed compression adjustment on my 2001 gasgas ec250 I don't want to turn it out if it is not thank you
Harry Member Mar 20, 2018 #3 Hi, I am not sure if the 01 has both high and low speed adjustment. I seem to remember there is a difference in the colour of the anodizing on the 17mm hex which indicates if has both. One is silver and one is gold ??
R rvktm New member Mar 20, 2018 #4 05 on had hs comp the ohlins top casting changed in i think 03 04 to more of a cr upright type
M Marc02ec250 New member Mar 22, 2018 #5 It is anodized gold I just don't want t to back it out if it's not an adjustment
nknudsen Member Mar 22, 2018 #6 The only adjustment is the "flat head screw" adjustment, not the big hex on the earlier bikes. That hex holds the assembly into the shock body.
