How deep can I drill? 2001 ec250 Shrouds, tank
lynngarner
I need to redo a couple of the holes in the black part of the gas tank where the radiator shrouds screw on. How deep can I safely drill into the black part of the tank to set new threads without penetrating the actual tank?
These holes should accommodate 6mm screws, right?
The holes really can't be drilled out. It's best to take a soldering gun and melt a black tie strap into the cavity.
Just trying to understand why the holes cannot be drilled out to receive a brass insert of some kind. 6mm is the correct size screw, right?
Unless the plug has been broken or pulled out I would just use a larger diameter screw. As I recall the plastic plugs you screws into are roughly about 1cm deep. The stock screws are a coarse thread screw (approx 4 or 5mm) like a wood screw without a sharp point. At 6mm it sounds like they holes are already oversized and stripped. I have used these products cut to length if the plug has fallen out. https://www.zoro.com/zoro-select-th...mKGiauxdOp-mpm40XLn6kEFatfsRVRmcaAiUKEALw_wcB
The soldering iron is a good idea too but don't go too deep.:D
