How to remove clocks
On my 09 EC 125 I have the red rectangular clocks , but they've never worked since I had the bike , how do the clocks come off so I can maybe try changing the batteries etc
The bracket is fixed to the top triple clamps with a couple of M5(?) screws. If you undo them, I think you will figure out the rest.
The headlight is fastened by rubber bands around the fork legs. Undo the two rubber bands at the top and the headlight assembly can be lifted up / forward.
You can also probably remove the battery from the underside of the speedo using a coin once the headlight is off
