How to tell what pipe I have (FMF???)
Zrt1200
I have a 05 ec200 that has a fatty pipe on it. How do I find out if its a 200 pipe or a 250 pipe?? I herd there is some marking on the head pipe some place?? Thanks Guys.
As I recall the FMF pipes were all the same between the 200, 250 and 300s. I believe the Messico pipes were 200 specific, but the big bore 200 will likely be happier with the bigger bike pipe.
If I remember correctly, the part number is stamped into the upper pipe hanger tab... worth a look and then you could compare to FMF's site.
I bought a new FMF Gnarly for my 200, seems like they listed the same pipe for all three engine sizes. Model range was from (maybe?) 2000 to 2009.
RB
Thats why I am trying to find out what pipe I have. I want to make sure its not a 200 pipe only.
Thanks and you are correct as I found it on the back side of the upper mount bracket.
Well I found then number and its stamped 084-025049. Then I went FMF web site and..... Use this manual for:
025049 - IPN-GAS GAS 200'03-05 F-PIPE
So its a 200 pipe only which is good for my 200 but not sure if it will be so good for my big bore that is being built??
